Issues with Brakes, M5 Display, and Speed on VESC 75100
asaf1462
Hi everyone,
I need some help with a few issues in my system. I’d appreciate any guidance:
    1.    Brakes connection to the controller:
I connected the positive and negative wires of the brakes (which are supposed to cut off the motor when pressed) to the ADC2 input – positive to the positive terminal and negative to GND.
Is this connection correct? If not, how should the brakes be connected to work properly? Additionally, I’d appreciate a detailed explanation of how to set up the brakes correctly on the VESC 75100.
    2.    M5 display:
I have an M5 display, and I’m not sure if my controller (VESC 75100) supports it.
If it does, how should I connect it to the controller properly? I’d love a step-by-step guide or a connection diagram if available.
    3.    Top speed:
Here’s my current setup:
    •    48V, 21Ah battery, 4C cells
    •    1000W motor
    •    VESC 75100 controller
Previously, I used an FB 500W controller with 32A, and the top speed was higher than what I’m achieving now.
What do you think could be the issue? I suspect the new controller might not be optimally configured. I’d appreciate recommendations for VESC 75100 settings that would suit my setup.
Thank you in advance for your help!
