Abs current
badger1666
Abs current
I have read on here about and abs current being turned up past the stock 150amps ,how's this possible ? Mine will not go above 150a is it a.special firmware ?? How can I get higher abs .
The value in the firmware is a value that hopes to keep your hardware from blowing up. Exceeding that is entirely at your own risk: You might blow up your vesc and you will.
Yes, the hardware-max is burned into the firmware, you'll have to download and compile your own firmware with the increased setting.
badger1666
Oh ok. Just wanted to up abs 165amp
To stop it's faulting when I set motor to 120amps
C green
