BT module and UART remote simultaneously on dual vescs
Rc 44
Last seen: 11 months 1 day ago
My setup uses two trampa vesc 6 connected via CAN, and I'm using a solidgeek based receiver connected via UART to the master Vesc. Would it be possible to connect an additional Bluetooth module to the uart port on the slave vesc to use mobile vesc tool data logging? Both the receiver and BT module would be using CAN forwarding potentially at the same time. Would that be an issue?
Rc 44
Update: it works just fine, no interruptions from either ends
