Phase not working on a three phase induction linear motor
Teyva
Last seen: 3 years 1 week ago
I every body,
I'm trying to use the vesc for a three phase induction motor, but when a set it up, one of the three phase doesn't seems to work at all. So I get too output from the other phases phaseshift by pi. I don't really know if this is because of a shortcircuit or if it's a configuration problem.
I'm using foc mode with a resistance of 104,08 ohm and a inductance of 1878 microH. When I try to automise the configuration, it tells me that there is no inductance so I don't no if my flux linkage, current ki/kp and observer gain are well set up.
To run the motor, I'm use foc_openloop 01 300. I've tried to increase the current to 05 but it just refine the curve output, and when I change the foc parameters it doesn't seems to change anything at all.
Thanks for your help,
Tom
offroader
If I'm not mistaken, VESC does not support induction motors. Openloop can theoretically work, but the settings must be adjusted
