Phase not working on a three phase induction linear motor
Teyva
I every body,
I'm trying to use the vesc for a three phase induction motor, but when a set it up, one of the three phase doesn't seems to work at all. So I get too output from the other phases phaseshift by pi. I don't really know if this is because of a shortcircuit or if it's a configuration problem.
I'm using foc mode with a resistance of 104,08 ohm and a inductance of 1878 microH. When I try to automise the configuration, it tells me that there is no inductance so I don't no if my flux linkage, current ki/kp and observer gain are well set up.
To run the motor, I'm use foc_openloop 01 300. I've tried to increase the current to 05 but it just refine the curve output, and when I change the foc parameters it doesn't seems to change anything at all.
Thanks for your help,
Tom
offroader
Last seen: 1 year 1 week ago
If I'm not mistaken, VESC does not support induction motors. Openloop can theoretically work, but the settings must be adjusted
