How to change vesc Hardware setting
Arman Karkotsyan
Hey yall how do i change the Hardware Vesc from 75/300 to Trampas 6/75 in Firmware Tab?
If you loaded the wrong FW you need to upload the correct one via  CUSTOM FILE.
Download the correct FW here: https://github.com/vedderb/vesc_tool/tree/release_3_01/res/firmwares
After the swap things are back to normal.
The BETA FW can be found here: https://github.com/vedderb/vesc_tool/tree/master/res/firmwares
The 60_75 file is the correct FW for the VESC 6/75
