Vesc PAS (Pedal Assist)
Evwan
Howdy everyone,
I noticed that vesc  firmware seemingly has a Pedal assist (PAS) + ADC app for ebikes.  I just built an ebike with a vesc based controller, and I was wondering if anyone knows if its been fully implemented and how it would interface with hardware? Thanks
jimmyoco@gmail.com
Good question. It is disappointing that some many interesting and useful posts go unanswered. What is wrong with this forum?
Snabelost
Lack of email notification I think.
blowman
Here is my code implementing PAS assist using PPM input for this sensor https://nexun.pl/en/products/pas-sensor-isis-hollowtech-version-d2-waterproof-higo-connector-947.html
Upload it from Lisp tab in VESC Dev Tools. ADC APP need to be configured. I used ADC1 for throttle but it can be changed in the code to ADC2.
; Single line PAS sensor waveform
;      ____          ____
;         ^-pulse width-^
; On reverse direction of pedaling the signal is at high state all the time
; When not pedaling(or very slow) the motor is disabled
; When pedaling is detected the ADC APP is enabled and throttle sets assists current
; I removed a spring from the throttle and put a piece of felt inside so
; the throttle stays at set position
(gpio-configure 'pin-ppm 'pin-mode-in-pd) ; use PPM input
(define MAGNETS 12)
(define MIN_PULSE 0.3) ;seconds, above this pulse width assist is disabled
(define pulse 0) ; PAS pulse width
(define last_pulse 0)
(define last_pas_pin 0)
(define last_pas_t 0)
(define assist 0)
(define assist_cnt 0)
(define pas_rpm 0)
(define riding_stops2 0) ;debug
(defun set-assist (assist1)
  (progn
    (define assist (if assist1 1 0))
    (if assist1
      (app-adc-detach 1 0) ; engage throttle current, attach ADC1 to enable the motor
      (progn ; else
        (app-adc-detach 1 2) ; detach ADC1 to disable the motor
(set-assist nil) ; disable assist at startup
; main loop
(loopwhile t ;run at 1000Hz (sleep 0.001)
  (progn
    (define pas_pin (gpio-read 'pin-ppm)) ; read PAS pin
    (if (!= pas_pin last_pas_pin)
      (if (= pas_pin 0) ; measure pulse width on falling edge
        (progn
          (define last_pulse pulse)
          (define pulse (secs-since last_pas_t))
          (define last_pas_t (systime))
          ;(define pas_rpm (* 60 (/ (/ 1.0 MAGNETS) pulse)))
          (if (and (= 0 assist) (< pulse MIN_PULSE)) ; detect pedaling when pulse is shorter than MIN_PULSE sec
            (progn
              (define assist_cnt (+ assist_cnt 1))
              (if (>= assist_cnt 2) ; enable assist when at least 2 short pulses detected
                (set-assist t)
          (if (and (= 1 assist) (> pulse (* last_pulse 1.25))) ; detect rapid PAS slowdown
            (progn
              (set-assist nil)
              (define riding_stops2 (+ 1 riding_stops2)) ; debug
          ;(define pulse_change (/ pulse (+ 0.0001 last_pulse))) ; debug
    (define last_pas_pin pas_pin)
    ; detect very-slow/not pedaling
    (if (and (= 1 assist) (> (secs-since last_pas_t) MIN_PULSE))
      (set-assist nil)
    (sleep 0.001)
Sandro luis
Last seen: 4 weeks 1 day ago
how to configure the adc app, what are the parameters please, thanks for sharing!
Sandro luis
Como mudar para adc2 no script?
wraven
wonder if would be possible to use adc3 pin on some controllers to make it a torque sensor with lisp
mariuszdymon
; Proporcjonalne wspomaganie PAS dla KT-V12L (12 magnesów)
; Funkcje: Soft Start, Proporcjonalna Moc, Auto-Cutoff, MIKSER MANETKI
; --- PARAMETRY KONFIGURACYJNE --- to trzeba pozmieniać pod swój system , parametry muszą być z . jak 1.0 nie 1
(define MAGNETS 12.0)
(define MIN_PULSE 0.5)
(define MIN_RPM 15.0)
(define MAX_RPM 80.0)
(define MIN_ADC 0.8)
(define MAX_ADC 3.2)
(define SOFT_START 0.05) ; 0.01 = bardzo wolny, 0.1 = szybki start
; --- ZMIENNE ROBOCZE ---
(define pulse 0)
(define assist 0)
(define pas_rpm 0)
(define target_adc 0)
(define current_adc 0)
; --- FUNKCJA STERUJĄCA ---
(defun set-assist (enable)
(progn
(define assist (if enable 1 0))
(if enable
(app-adc-detach 1 2) ; Przejęcie kontroli nad systemowym ADC
(progn
(app-adc-detach 1 0) ; Oddanie pełnej kontroli manetce
(app-adc-override 0 0)
(define pas_rpm 0)
(set-assist nil)
; --- GŁÓWNA PĘTLA ---
(loopwhile t
(progn
(if (= pas_pin 0)
(progn
; Obliczanie RPM
(define pas_rpm (* 60.0 (/ (/ 1.0 MAGNETS) pulse)))
; Logika Startu (wymaga 2 impulsów)
(if (and (= 0 assist) ( (progn
(if (>= assist_cnt 2) (set-assist t))
; Obliczanie mocy z pedałów (Target ADC)
(if (= 1 assist)
(progn
(define rpm_factor (/ (- pas_rpm MIN_RPM) (- MAX_RPM MIN_RPM)))
(if ( (if (> rpm_factor 1) (define rpm_factor 1))
(define target_adc (+ MIN_ADC (* rpm_factor (- MAX_ADC MIN_ADC))))
; Szybkie wyłączanie przy gwałtownym zwolnieniu pedałowania
(if (and (= 1 assist) (> pulse (* last_pulse 1.45)))
(set-assist nil)
; LOGIKA SOFT START i MIKSERA MANETKI (wykonywana co 1ms)
(if (= 1 assist)
(progn
; 1. Płynne narastanie napięcia z PAS (Soft Start)
(define diff (- target_adc current_adc))
(define current_adc (+ current_adc (* diff SOFT_START)))
; 2. Odczyt fizycznego napięcia z manetki (ADC1 -> kanał 0 w Lisp)
(define throttle_adc (get-adc 0))
; 3. Wybór wyższej wartości (Manetka czy PAS?)
(define final_adc (if (> throttle_adc current_adc) throttle_adc current_adc))
; 4. Wysłanie wygranej wartości do silnika
(app-adc-override 0 final_adc)
; Timeout bezpieczeństwa (całkowite zatrzymanie pedałów)
(if (and (= 1 assist) (> (secs-since last_pas_t) 0.4))
(set-assist nil)
(sleep 0.001)
