Vesc PAS (Pedal Assist)
Evwan
Last seen: 2 weeks 1 day ago
Howdy everyone,
I noticed that vesc  firmware seemingly has a Pedal assist (PAS) + ADC app for ebikes.  I just built an ebike with a vesc based controller, and I was wondering if anyone knows if its been fully implemented and how it would interface with hardware? Thanks
jimmyoco@gmail.com
Good question. It is disappointing that some many interesting and useful posts go unanswered. What is wrong with this forum?
Snabelost
Lack of email notification I think.
blowman
Here is my code implementing PAS assist using PPM input for this sensor https://nexun.pl/en/products/pas-sensor-isis-hollowtech-version-d2-waterproof-higo-connector-947.html
Upload it from Lisp tab in VESC Dev Tools. ADC APP need to be configured. I used ADC1 for throttle but it can be changed in the code to ADC2.
; Single line PAS sensor waveform
;      ____          ____
;         ^-pulse width-^
; On reverse direction of pedaling the signal is at high state all the time
; When not pedaling(or very slow) the motor is disabled
; When pedaling is detected the ADC APP is enabled and throttle sets assists current
; I removed a spring from the throttle and put a piece of felt inside so
; the throttle stays at set position
(gpio-configure 'pin-ppm 'pin-mode-in-pd) ; use PPM input
(define MAGNETS 12)
(define MIN_PULSE 0.3) ;seconds, above this pulse width assist is disabled
(define pulse 0) ; PAS pulse width
(define last_pulse 0)
(define last_pas_pin 0)
(define last_pas_t 0)
(define assist 0)
(define assist_cnt 0)
(define pas_rpm 0)
(define riding_stops2 0) ;debug
(defun set-assist (assist1)
  (progn
    (define assist (if assist1 1 0))
    (if assist1
      (app-adc-detach 1 0) ; engage throttle current, attach ADC1 to enable the motor
      (progn ; else
        (app-adc-detach 1 2) ; detach ADC1 to disable the motor
(set-assist nil) ; disable assist at startup
; main loop
(loopwhile t ;run at 1000Hz (sleep 0.001)
  (progn
    (define pas_pin (gpio-read 'pin-ppm)) ; read PAS pin
    (if (!= pas_pin last_pas_pin)
      (if (= pas_pin 0) ; measure pulse width on falling edge
        (progn
          (define last_pulse pulse)
          (define pulse (secs-since last_pas_t))
          (define last_pas_t (systime))
          ;(define pas_rpm (* 60 (/ (/ 1.0 MAGNETS) pulse)))
          (if (and (= 0 assist) (< pulse MIN_PULSE)) ; detect pedaling when pulse is shorter than MIN_PULSE sec
            (progn
              (define assist_cnt (+ assist_cnt 1))
              (if (>= assist_cnt 2) ; enable assist when at least 2 short pulses detected
                (set-assist t)
          (if (and (= 1 assist) (> pulse (* last_pulse 1.25))) ; detect rapid PAS slowdown
            (progn
              (set-assist nil)
              (define riding_stops2 (+ 1 riding_stops2)) ; debug
          ;(define pulse_change (/ pulse (+ 0.0001 last_pulse))) ; debug
    (define last_pas_pin pas_pin)
    ; detect very-slow/not pedaling
    (if (and (= 1 assist) (> (secs-since last_pas_t) MIN_PULSE))
      (set-assist nil)
    (sleep 0.001)
Sandro luis
Last seen: 4 weeks 1 day ago
how to configure the adc app, what are the parameters please, thanks for sharing!
Sandro luis
Como mudar para adc2 no script?
wraven
Last seen: 1 week 4 days ago
wonder if would be possible to use adc3 pin on some controllers to make it a torque sensor with lisp
mariuszdymon
; Proporcjonalne wspomaganie PAS dla KT-V12L (12 magnesów)
; Funkcje: Soft Start, Proporcjonalna Moc, Auto-Cutoff, MIKSER MANETKI
; --- PARAMETRY KONFIGURACYJNE --- to trzeba pozmieniać pod swój system , parametry muszą być z . jak 1.0 nie 1
(define MAGNETS 12.0)
(define MIN_PULSE 0.5)
(define MIN_RPM 15.0)
(define MAX_RPM 80.0)
(define MIN_ADC 0.8)
(define MAX_ADC 3.2)
(define SOFT_START 0.05) ; 0.01 = bardzo wolny, 0.1 = szybki start
; --- ZMIENNE ROBOCZE ---
(define pulse 0)
(define assist 0)
(define pas_rpm 0)
(define target_adc 0)
(define current_adc 0)
; --- FUNKCJA STERUJĄCA ---
(defun set-assist (enable)
(progn
(define assist (if enable 1 0))
(if enable
(app-adc-detach 1 2) ; Przejęcie kontroli nad systemowym ADC
(progn
(app-adc-detach 1 0) ; Oddanie pełnej kontroli manetce
(app-adc-override 0 0)
(define pas_rpm 0)
(set-assist nil)
; --- GŁÓWNA PĘTLA ---
(loopwhile t
(progn
(if (= pas_pin 0)
(progn
; Obliczanie RPM
(define pas_rpm (* 60.0 (/ (/ 1.0 MAGNETS) pulse)))
; Logika Startu (wymaga 2 impulsów)
(if (and (= 0 assist) ( (progn
(if (>= assist_cnt 2) (set-assist t))
; Obliczanie mocy z pedałów (Target ADC)
(if (= 1 assist)
(progn
(define rpm_factor (/ (- pas_rpm MIN_RPM) (- MAX_RPM MIN_RPM)))
(if ( (if (> rpm_factor 1) (define rpm_factor 1))
(define target_adc (+ MIN_ADC (* rpm_factor (- MAX_ADC MIN_ADC))))
; Szybkie wyłączanie przy gwałtownym zwolnieniu pedałowania
(if (and (= 1 assist) (> pulse (* last_pulse 1.45)))
(set-assist nil)
; LOGIKA SOFT START i MIKSERA MANETKI (wykonywana co 1ms)
(if (= 1 assist)
(progn
; 1. Płynne narastanie napięcia z PAS (Soft Start)
(define diff (- target_adc current_adc))
(define current_adc (+ current_adc (* diff SOFT_START)))
; 2. Odczyt fizycznego napięcia z manetki (ADC1 -> kanał 0 w Lisp)
(define throttle_adc (get-adc 0))
; 3. Wybór wyższej wartości (Manetka czy PAS?)
(define final_adc (if (> throttle_adc current_adc) throttle_adc current_adc))
; 4. Wysłanie wygranej wartości do silnika
(app-adc-override 0 final_adc)
; Timeout bezpieczeństwa (całkowite zatrzymanie pedałów)
(if (and (= 1 assist) (> (secs-since last_pas_t) 0.4))
(set-assist nil)
(sleep 0.001)
