Anti cogging, suppressing torque ripple?
Alistair Goodman
Hi guys,
I am using my VESC and BLDC motor as a variable brake, and need smooth operation at low speeds, however due to the torque ripple of the motor I am experiencing some problems.
I am wondering if anyone has looked into or used any anti-cogging algorithms like those discussed here https://hackaday.com/2016/02/23/anti-cogging-algorithm-brings-out-the-best-in-your-hobby-brushless-motors/ ?
What do you guys think of this, is there a place for this in the VESC code and how easy could it be implemented?
Any input is really appreciated!
AG
I guess you want to attach an AS5047P sensor in this case.
https://trampaboards.com/resources/manuals/207.pdf
Alistair Goodman
Thanks Frank, I assume you're saying that using this sensor will provide the appropriate position resolution to implement some torque ripple compensation? I would still need to implement my own torque correction algorithm though?
Ali goodman
With sensors it should be very smooth throughout the entire low speed RPM range.
Alistair Goodman
Great thanks, I am currently using a 1024 bit incremental encoder, do you think this sensor will work much better at low speeds?
Ali goodman
