Axial Flow Pump Project
design@imsltd.co.nz
Hi All
We are experimenting on an axial flow pump using the Flipsky 65121 120kV motor & 200A FSECS (see Image below)
For our testing we used a servo tester to start/stop the motor. This worked OK during our testing.
We now wish to be able to simply switch the motor on/off with a toggle type switch.
Can anyone offer a way we can simply switch the motor on/off?
Thanks for that
David
A high side switch could be used as solid state on off device.
if a pot would been used as speed ref, it could be made 0v on the ref. to make a stop.
design@imsltd.co.nz
OK - thanks. Will give it a go.
