Wheels only rotate about a quarter of a turn
Appearance
Just looking for some advice. Configured motors on the VESC and all semeed well, they spin when testing. Unfortunately, when I try to accelerate using the remote (board is upside down), the wheels just turn a quarter, stop, and the remote beeps. Links of setup are attached. Advice would be great!
Motors:
https://www.amazon.com/Hobbysky-Brushless-Outrunner-Skateboard-Surfboard/dp/B07JNBGMJV/ref=sr_1_5?keywords=hobbysky%2Bmotor&qid=1560391662&s=sports&sr=1-5&th=1&psc=1
ESC:
https://flipsky.net/products/dual-fsesc4-20-100a-plus-based-on-vesc-with-anodized-aluminum-heatsink?_pos=11&_sid=00d13aea0&_ss=r
Battery: http://www.diyeboard.com/10s5p-360wh-18650-battery-power-kit-with-bmscha...
dsuresh
when you setup the remote are you using teh correct method, like adc or ppm, etc? I used a potentiometer and it worked for me and I had no issues with that
Dave
drummerboy5408
Last seen: 5 months 4 days ago
make sure your battery cutoff voltage is set correctly for you battery voltage.
Sometimes it doesn't like to save, and will cause this exact issue
