Wheels only rotate about a quarter of a turn
Appearance
Just looking for some advice. Configured motors on the VESC and all semeed well, they spin when testing. Unfortunately, when I try to accelerate using the remote (board is upside down), the wheels just turn a quarter, stop, and the remote beeps. Links of setup are attached. Advice would be great!
Motors:
https://www.amazon.com/Hobbysky-Brushless-Outrunner-Skateboard-Surfboard/dp/B07JNBGMJV/ref=sr_1_5?keywords=hobbysky%2Bmotor&qid=1560391662&s=sports&sr=1-5&th=1&psc=1
ESC:
https://flipsky.net/products/dual-fsesc4-20-100a-plus-based-on-vesc-with-anodized-aluminum-heatsink?_pos=11&_sid=00d13aea0&_ss=r
Battery: http://www.diyeboard.com/10s5p-360wh-18650-battery-power-kit-with-bmscha...
dsuresh
when you setup the remote are you using teh correct method, like adc or ppm, etc? I used a potentiometer and it worked for me and I had no issues with that
Dave
drummerboy5408
make sure your battery cutoff voltage is set correctly for you battery voltage.
Sometimes it doesn't like to save, and will cause this exact issue
