VESCs rotating the motors at constant RPM on UART control
Pratham701
So I have connected my VESC 4.21 to a 190KV motor. Using UART, I have paired an Arduino Due with it and powering the VESC with 24 volts. I am using SolidGeek's library(https://github.com/SolidGeek/VescUart) to run the motors.
Issues:
1. When I try to use the setNunchuck value function, the motor runs unpredictability. idealy, it should spin clockwise for values 0-127, and the other way for 127-155. What happens is the motor doesn't start until I reach 150 value, at which it attends the constant rpm, which isn't even the max value, and doesn't respond to changes in the nunchuck values.
2. I used the setCurrent function for the same, and the behaviour is more or less the same. Doesn't run till a point, then starts with a jerk and attains a constant rpm, and then doesn't respond to any change to the current value, unless stopped.
Is the issue of VESC tool? Or is the VESC getting constrained to some parameters? I have the proper battery, as the motor works fine when I run it on the tool.
Indy8976
Last seen: 10 months 4 weeks ago
Hi, I hope it is not too late,
May be the problem is that Serial in Arduino Due outputs and inputs are in 3.3V and not in 5V as Arduino UNO; probably you have to buy a Logic Level Converter that increase output tension from 3.3V to 5V in putput and downgrade from 5V to 3.3V in input.
A try you can have is to upload the code ( use SoftwareSerial for multiple VESC ) to an Arduino UNO and see what happens. This because output in Arduino UNO is 5V
