Regen on the positive side of the throttle curve?
kcswimrac
Is it possible to set up the regen to be active on coast/ the first few percent of positive throttle input.
Something like how teslas 0-5% throttle is actualy regen, then 5-100% is actual throttle signal?
Thank you.
Yes. You would need to select Current No Reverse Brake Center option for the throttle. Releasing the throttle will kick in regen. You can also tune your specific throttle voltages for the regen to kick in at whatever percent of the throttle you want it to engage. I never tested as I like my bike to coast freely whenever possibly and use only variable regen when needed. But it should work.
