Custom code changes- I/O pin go high or low
dsuresh
Can I set a pin to go high under a certain condition for example: when the battery is lower than a certain value, can I make one of the pins to go high or low? and if so how can I make that happen?
You could have checked the vesc code and found examples or read ChibiOS but that's one way to do it:
 if (condition)  {
                                palSetPad(GPIOx, x); or
                               palClearPad(GPIOx, x);
dsuresh
Hi Vadicus,
I am thinking of using the RX pin out and I checked it on the Sch it shows as GPIOB 11.
So if does the following makes sense?
 if (condition)  {
                                palSetPad(GPIOB_Pin 15, 15)
Dave
