12v(3s) Input to VESC 75/250
AliBarrett10
Hi.
I'm looking for a VESC which can pull 2kW, but at 12V for short perioods (2-3mins)
The VESC mkV has 100a continous and 120a burst, but sounds like this won't be beefy enough.
There are chinese VESC based that say 200a, but after doing research i don't believe they will pull the current required.
How about the VESC 75/250~?
This can pull the amps required but only shows support for 14v minimum.
Is there a reason that this can't be run on 12v to do with the power delivery, or is it because there is it simply because there is a  12v BEC on board?
Would it be possible to use on 3s and not have the 12v BEC working? or disconnect it?
Thanks in advance.
Ali
