Documentation
Cledus
Documentation
Hi!
I was wondering where to find some documentation on how to communicate with the VESC to be able to change parameters via an app or a bluetooth device?
Oyta
VESC FreeVESC GoldVESC Original
Hi! The current VESC-hardware has no Bluetooth per default. Some have the NRF-module implemented but phones normally does not have a NRF-module. There are however some options on the marked like https://metr.at/ This guy sells Bluetooth modules that you can connect to the VESC and then you can use his app. I use it and the app is nice. There are some other options and also an open source project on going. This project looks promising: https://github.com/bradrisse/Esk8 and http://www.electric-skateboard.builders/t/new-esk8-app-for-ios-and-andro... guy started the project seems to be experienced in designing apps.
If you want to connect with the NRF-module you should look at the Nunchuck software on Benjamin Vedders GitHub. You can also look at this project: http://www.electric-skateboard.builders/t/simple-3d-printed-nrf-remote-a...
