ennoid bms
roqm
Last seen: 6 years 2 weeks ago
ennoid bms
hello i am having an issue changing parameters, when using the parameter config editor tool under the developer tab, i am able to change values and save there and also save values as a xml problem is when i go back to the main page to set up the bms configuration none of the values i changed are available ie change "noOfParallelModules" from default value of 10 to 30 when i save and close page the values are still 10 on main page....please help. p.si am not connected to the bms(i dont have it yet)
