Compiling Error Windows 10
Christian
Hello everybody,
I try to compile the firmware from vedders git, but it does not work for me, I always get the error code:
arm-none-eabi-gcc -x assembler-with-cpp -c -mcpu=cortex-m4 -Wa,-amhls=build/lst/crt0_v7m.lst -DCORTEX_USE_FPU=TRUE  -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -mthumb -MD -MP -MF .dep/crt0_v7m.o.d -I. -IChibiOS_3.0.2/os/common/ports/ARMCMx/devices/STM32F4xx -IChibiOS_3.0.2/os/ext/CMSIS/include -IChibiOS_3.0.2/os/ext/CMSIS/ST -IChibiOS_3.0.2/os/rt/include -IChibiOS_3.0.2/os/rt/ports/ARMCMx -IChibiOS_3.0.2/os/rt/ports/ARMCMx/compilers/GCC -IChibiOS_3.0.2/os/hal/osal/rt -IChibiOS_3.0.2/os/hal/include -IChibiOS_3.0.2/os/hal/ports/common/ARMCMx -IChibiOS_3.0.2/os/hal/ports/STM32/STM32F4xx -IChibiOS_3.0.2/os/hal/ports/STM32/LLD -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/DACv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/GPIOv2 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/I2Cv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/OTGv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/RTCv2 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/SPIv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/TIMv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/USARTv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/FSMCv1 -IChibiOS_3.0.2/os/various -IChibiOS_3.0.2/os/hal/lib/streams -Imcconf -Iappconf -Ihwconf -Iapplications -Inrf -IChibiOS_3.0.2/ext/stdperiph_stm32f4/inc ChibiOS_3.0.2/os/common/ports/ARMCMx/compilers/GCC/crt0_v7m.s -o build/obj/crt0_v7m.o
ChibiOS_3.0.2/os/common/ports/ARMCMx/compilers/GCC/rules.mk:217: recipe for target 'build/obj/crt0_v7m.o' failed
process_begin: CreateProcess(NULL, arm-none-eabi-gcc -x assembler-with-cpp -c -mcpu=cortex-m4 -Wa,-amhls=build/lst/crt0_v7m.lst -DCORTEX_USE_FPU=TRUE -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -mthumb -MD -MP -MF .dep/crt0_v7m.o.d -I. -IChibiOS_3.0.2/os/common/ports/ARMCMx/devices/STM32F4xx -IChibiOS_3.0.2/os/ext/CMSIS/include -IChibiOS_3.0.2/os/ext/CMSIS/ST -IChibiOS_3.0.2/os/rt/include -IChibiOS_3.0.2/os/rt/ports/ARMCMx -IChibiOS_3.0.2/os/rt/ports/ARMCMx/compilers/GCC -IChibiOS_3.0.2/os/hal/osal/rt -IChibiOS_3.0.2/os/hal/include -IChibiOS_3.0.2/os/hal/ports/common/ARMCMx -IChibiOS_3.0.2/os/hal/ports/STM32/STM32F4xx -IChibiOS_3.0.2/os/hal/ports/STM32/LLD -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/DACv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/GPIOv2 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/I2Cv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/OTGv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/RTCv2 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/SPIv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/TIMv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/USARTv1 -IChibiOS_3.0.2/os/hal/ports/STM32/LLD/FSMCv1 -IChibiOS_3.0.2/os/various -IChibiOS_3.0.2/os/hal/lib/streams -Imcconf -Iappconf -Ihwconf -Iapplications -Inrf -IChibiOS_3.0.2/ext/stdperiph_stm32f4/inc ChibiOS_3.0.2/os/common/ports/ARMCMx/compilers/GCC/crt0_v7m.s -o build/obj/crt0_v7m.o, ...) failed.
make (e=2):
I am using eclipse oxygen with the GNU Arm Toolchain.
Does somebody know the problem?  Or maybe a solution for this issue?
Last seen: 12 months 3 days ago
You quoted the make process starting a compiler. And the next thing it does is that it says that the command failed. Normally there is an error in between. Like: "gcc: error: undefined variable asdfljkdskf" .
Svenska Svenson
As far as I'm aware, all the VESC software was developed under Ubuntu. It might be worth to look at the Win10 inbuilt Linux magic and see if you have more luck with that. It is a Ubuntu based thing.
Might work?
-Sven
