VESC 6 Mark III and Traxxas Summit Radio Receiver PWM / PPM Signals
j98221@gmail.com
hi,
trying to get this working. I have a traxxas rc (summit). the radio receiver outputs pwm but your vesc has ppm input. Also trying to use this with navio2 flight controller hat for raspberry pi microcontroller. it also outputs pwm not ppm. i do have a ppm encoder but i currently have it connected from the radio receiver to the navio2 flight controller hat for raspberry pi microcontroller. i can get another ppm encoder to connect the throttle pwm output from the navio2 to the ppm input of your vesc but will it work if i only use it for the throttle?
Thank you in advance and be well.
