How to get vesc tool for linux on ubuntu?
vitormhenrique
Last seen: 2 years 4 weeks ago
Hello everyone,
This might be a stupid question, but I downloaded the compiled zip file for the vesc tool for linux, and I can not get it started on ubuntu.
What type of file is it? a .deb installation file? an executable?
I could not find anywhere instructions (i assume is so basic that no one needed)
Best regards,
Vitor Henrique
vitormhenrique
Tried the obvious and made the file executable and ran but got the error message:
./vesc_tool_1.25: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
Downloaded the source code and compiled and got the program to start, but the bluetooth module does not work, and that is what i wanted to use....
Got the following error on my compiled version:
qt.bluetooth: Dummy backend running. Qt Bluetooth module is non-functional
vitormhenrique
compiling with qt creator worked!
I think a newer version of libssl became available recently hence the error. I'm guessing you are using a fairly recent version of Ubuntu?
vitormhenrique
Yeah, I'm using Ubuntu 19.10...
sandersesurf
Hi, Im having issues getting the VESC tool to open at all. Im running ubuntu 21.04 on a raspberry pi 4. I have downloaded the linux vesc tool and unzipped, that takes me to an icon (vesc_tool_3.00) and will not open or do anything at all. Not sure how to fix???
sanketh1691
Try to run it in terminal, it will show you if there is any error and then you can proceed from there. The error could be mostly this "./vesc_tool_3.00: error while loading shared libraries: libSDL2-2.0.so.0: cannot open shared object file: No such file or directory". Then you can use this to install it - "sudo apt-get install git curl libsdl2-mixer-2.0-0 libsdl2-image-2.0-0 libsdl2-2.0-0"
JackGunnarsson
Thanks guys
Jack Gunnarsson
