Máximo Voltaje Android
Oscarmanassan
Last seen: 4 years 1 day ago
Hello, I bought the Android application in the Play store and I can't find the tab to choose the maximum voltage, the PC application doesn't work correctly for me and I can't access the tab from the mobile application.
Could someone tell me if that maximum voltage tab exists in Android?
Gatze
I don't know of any possibility to adjust the maximum voltage, it is also not really logical, because your battery determins the maximum voltage and the motor and VESC should be adjusted to it.
Can you explain why you need to adjust the maximum voltage ? Is to control the rpm ? There are otherways to do that.
Oscarmanassan
because my 75100 is limited to 74v. my battery is 20 s and when it is above 74 volts the maximum voltage error appears
Yo
Last seen: 10 months 4 days ago
75 V rated units should not be operated above 16S. That is 67v and leaves 8v for voltage spikes.
