Kill switch
999dom999
Kill switch
Forgive my ignorance, to set either adc or ppm to low do I connect ground to the signal wire?
I have a scooter with hydraulic disc brakes and I want to cut the motor while braking. The brake levers have sensors that are 2 wire "normally open" so I can join the 2 wires between signal and ground and it will make a connection when I pull the lever. Just checking this is the way to do it?
Kill Switch Settings
Disabled
No kill switch is used.
PPM Low
The kill switch is active when the PPM input goes low.
PPM High
The kill switch is active when the PPM input goes high.
ADC2 Low
The kill switch is active when the ADC2 input goes low.
ADC2 High
The kill switch is active when the ADC2 input goes high.
This is not really a good idea. The kill switch is only intended for safety cutoff and not to reduce the power occasionally. I don't see a reason for such an implementation. You let go the throttle and press the brakes... That it how it works on any motorbike and cars.
999dom999
Ok sorry I misinterpreted this function. My current scooter controller with brake sensors cuts the motor when the brake is pulled. This is for safety and stops the disc brake being applied while the motor is engaged, so they are not fighting against each other. What would be the best way to implement this with VESC?
Would you really hold the throttle while applying brakes? Sounds like a problem doesn't really need solving. On all my motorbikes you could perfectly throttle the engine while pressing the brakes.  But who would do that?
999dom999
I have an escooter and ebike, they both work this way. The brake cuts power to the motor.
Ok so if I want to add an emergency kill switch to hit if say the throttle get stuck open, can I short ppm signal to ground? And set the kill switch option to ppm low?
Last seen: 1 year 3 weeks ago
The kill switch can be wired in according to the VESC-Tool options. ADC or PPM, high or low. A external circuit that always pulls the ADC 1 throttle signal low when applying the brakes would be the best way to make sure that you can not pull the throttle while braking. However, releasing the brakes when the throttle is still pulled might also cause unexpected behavior. Not sure if that is so desirable in higher powered vehicles.
hnr_engineer
Last seen: 4 years 22 hours ago
Im not an electronics minded person but trying to set up the Kill function on ADC2 using a magnetic hall switch 3.3v.  So when it says ADC high or low what exactly do you need to feed it and how.
The hall switch has an analog and digital output but is there something more you need to add to the ADC input from the hall switch to allow it to recognize a high or low signal.
