Writing value to both VESCs on FocFox Unity
agraham
I’m having trouble making a change in VESC tool…
I installed a bigger battery, and most of the settings I want to change are accessible through the “Multi Settings” option:
After I make a change I can “Write to All VESCs”:
So far so good.
This one setting however is accessible through the “regular” settings not through the “Multi Settings”:
Instead of “Write to All VESCs” I only have “Write” and when I hit it, it only writes to the first VESC (not the secondary one on the CAN bus).
If I press that “CAN ->” button in the lower left, It detects “UNITY (LOCAL)” and “UNITY (70)” but if I try to select UNITY (70) the tool reboots and I get this:
Not sure what to do with this. It seems like the tool knows how to write to both VESCs when going through the "Multi Settings" so I imagine this should be possible without messing with USB or that pairing list however that is done.
Some settings do not need to be stored in both units. The Master side is controlling things and the slave side is only following. So gearing and battery settings etc are a masters side thing.
The Unity is not official Hardware and it only has one processor. So there is not really a master and slave processor. It is emulated that way only.
Last seen: 1 day 10 hours ago
The disconnect you see is probably because you used the pairing function. You can unpair and try again. But as Frank said, some settings don't really need to be set on both. The battery capacity is only used to calculate the remaining range and you only need it on the master to get it correct.
