In this tutorial we will configure a genuine VESC® motor controller in combination with a BLDC motor.
We will run the motor in FOC mode and we will make use of Hall sensors.
Connect your VESC® to your computer using a mini/micro USB cable.
Run the VESC®-Tool software.
Now we get the following options:
FOC = Field-Oriented Control
Advanced control mode (sinusoidal, silent, more efficient,
better motor sensor operation).
May cause damage to 3rd party hardware!
BLDC = Trapezoidal Control
More simple control mode (block commutation), noisier, hall-sensor operation
less accurate at this stage. Safer for operation of 3rd party hardware.
DC = Only for DC motors. Use phase wire A and C only!
The following explanations will help you to configure your current limits correctly:
Motor Current Max: The maximum current your motor can handle continuously (Ampere). Please refer to the motor specifications of your motor. You may use lower values to de-power your setup.
Our motor can handle 50A, but we will only set it to 30A to get started. You can boost your settings once you feel comfortable. A safe approach towards higher values is highly recommended (e.g. start with 15A only).
Hint: This value can be greater than the Battery Current Max value, resulting in a higher motor power output at part throttle. At max throttle the Battery Current Max is the limiting value if set lower than Motor Current Max.
Motor Current Max Brake: The maximum current output you allow your motor to produce when operated as a generator. Electric vehicles may use the motor as a brake, generating energy when slowing down the vehicle. The energy produced will be stored in the battery. In this tutorial we will set the value to -25A to get started. The value should not be higher than the max. continuous current specification of the motor.
Hint: Higher values will result in stronger brakes if the Battery Current Max Regen settings allows the storage of the current generated.
Battery Current Max: The maximum continuous current your battery is rated for. Please refer to your battery specifications for safe settings. LiPo-pack batteries are usually C-rated. A 5800mAh, 25C rated battery can handle 5.8A x 25=145A max. Manufacturers often overrate the batteries and cutting the value in half is recommend. We will use 72A max for safety reasons.
Hint: Since our Motor Current Max is set to 30A, we could use 30A for the battery as well.
Technically there is no reason to use a higher value than the Motor Current Max.
Battery Current Max Regen: The maximum current you allow the VESC to push towards your battery or battery management system (if incorporated in your system) when braking. This value should not exceed the maximum charge current rating of your battery or capability of your battery management system. Our battery is 5C rated for charging. We use a 5800mAh battery.
5.8A x 5 = 29A max. charge current. Again: Better be pessimistic with those values! We will set it to -20A.
Hint: Since this value is lower than the Motor Current Max Brake (-25A), the firmware will limit the ampflow towards the Battery to -20A, regardless of the higher value we specified for Motor Current Max Brake (-25A). In consequence our maximum motor brake force is limited by the lower Battery Current Max Regen value.
Now we will configure your battery cutoff voltage.
If you discharge your battery below a certain voltage, it will get damaged permanently. LiPo packs or Lithium ion Batteries usualy operate between 4.2V and 3.1V per cell. Do not allow your system to discharge them beyond 3.1V per cell! For this reason the VESC will measure your battery voltage and will start to softly cutoff the power at 3.4V per cell (Battery Votage Cutoff Start) and it will perform a hard cutoff at 3.1V per cell (Battery Votage Cutoff End).
You can also set custom values if your cells have different ratings.
Battery Voltage Cutoff End = number of cells in series x minimum cell voltage
Next step is the choice of motor sensors
Sensors help the VESC to know the rotor position in refenrence to the copper coils. This way the motor can perform a relatively smooth startup from 0 RPM. If your motor features sensors you should make use of them. At higher RPM, the VESC will use back EMFs to calculate the rotor position. The RPM for switching to back EMF operation can be defined later.
No sensors: without motor sensors the motor needs to turn a bit, so the VESC can calculate the rotor position from the back EMF current flow that the magnets will induce into the copper coils when they rotate around the the motor stator. Startup from 0 RPM is possible but a bit shaky.
Hall sensors: A transducer that varies its output voltage in response to a magnetic field. Usually a set of three sensors are acurately positioned inside or outside the motor to roughly determin the position of the rotor.
Commonly used, not very precise, good enough to guarnatee a smooth startup of a vehicle from standstill.
AS5047 Encoder: This is a chip sensing the magnetic field of a diametrally magnetized magnet, attached to the motor shaft. The precision is very high (14 bit) and allows very accurate determination of the rotor position.
ABI: Output signal of an incremental rotary encoder (mechanical, optical or magnetic).
Our motor has Hall sensors, so we will choose Hall sensor operation.
Next step is to measure your motor parameters
For the best possible result, do the detection without attached drive train, propellers etc.
Every single motor is unique and the VESC needs to know certain parameters to run the motor. The VESC needs to know the motor resistance, electrical inductance and flux linkage (λ). From these basic values other values can be calculated that are essential for the motor operation. So that‘s what we will do now.
Step 1:measure RL
The motor will make a loud humming noise
Step 2:measure λ
The motor will spin up. Make sure to disassemble propellers or lift up your vehicle from the ground or take any preparations necessary to allow your motor to spin up freely.
Step 3:Apply values
Make sure that your motor can rotate freely, since the motor will start to turn slowly now.
Congratulations, you have finished the Motor Setup Wizard.
Please continue with the Input Setup Wizard.
Comments
hi!
Thanks for the guide.. Very helpful!
Tom Clark/ Call us today
Great news.. ~ Driveway
Great news.. ~ Driveway Replacement, Lincoln, NE
slotgacor
Cool article slotgacor
thank you
I started a website blog lately, and the information you offer on this article helped me a lot. Thank you for your writing. slot77
Great blog article.Really
Great blog article.Really looking forward to read more! mawarslot
you need to read this
I could find useful information from your article, reading this is enlightening. I appreciate you spending your time and effort to put the wordings together. I find myself personally enjoying a significant amount of my time both to read and post this comment. But you know, it's worth! Slot Deposit Pulsa 10rb Tanpa Potongan
Cool article planet138
Cool article Pragmatic play
Cool article Pragmatic play indonesia
good post. never knew this,
good post. never knew this, thanks for letting me know! tas seminar kit
worth
Took my chance to read many feedbacks, yet I actually love this article. It's worth the time and I am particular to amazed by the entire commenters here! marketing online
Great!!!
Excellent information you have shared, thanks for taking the time to share with us such a great article. I really appreciate your work. ! Such a great post ! thanks for sharing !
dinosaur game
Cool article Agen slot
Cool article Agen slot terpercaya
This blog is very well
This blog is very well-written and interesting, all the articles have been written in detail. link slot deposit pulsa tanpa potongan
Cool article cara bobol wifi
Cool article cara bobol wifi tanpa aplikasi
Cool article Situs slot
Cool article Situs slot terpercaya
hey!
Excellent! This app is super handy and does everything needed to set up or make adjustments to a vesc via Bluetooth and smartphone.
- view page
great
Nice post! This is a very nice blog that I will definitively come back to more times this year! Thanks for informative post Pacman 30th Anniversary
Good
T he information on this blog is very helpful, im happy to stop by this blog. rental mobil silangit
Get to Work in Country of Your Choice
We have been helping our clients to move to their preferred locations for Tourism, Permanent Settlement, Set up & Expand Businesses Abroad, Study Abroad, Work Permit & Acquiring new Citizenship. Visa Ray Immigration & Work Visa Consultancy
Solution for Mobile Signal Reception Issues
The best and most reliable solution to solve any kind of mobile signal reception issue is to use a mobile phone signal booster
ufa168
Your article is very interesting. I think this article has a lot of information needed, looking forward to your new posts. ufa168
Yo!
The Motor Wizard is a simple way to configure your VESC versus manually configuring your VESC and not understanding the other features. It will allow you to properly configure your motor and battery pack with the VESC.
Jul - building maintenance companies sydney
Dear
Agree!
Parramatta Painters
I'm grateful you shared this useful knowledge. Your webpage is fantastic. Your website contains an incredible amount of information. Come to tiny fishing on behalf of my thanks.
Thanks for reading along and
Thanks for reading along and for the kind words. It is a great website Tower Defense and a nice share. I want to thank you. Good job! You guys do a great blog and have some great content. Highly recommend!
Who made Quardle?
A team of Wordle followers developed Quardle, which went on to play another Worlde spin-off, Dordle. Dordle is a version that allows two five-letter words to be assumed at once. On the Quardle website, creator Freddie Meyer said that designer David Mah put together an early prototype of the game in a "moment of bad luck and brilliance." Mayer said: "It was terrible code (it even had two keyboards), yet I knew I had to go madly. It lured me into completing its ominous product." He also credits Guilherme S. Pulls for the creation of the Quardle.
Mayer claims that the video game currently has more than 500,000 daily players and more than a million in reality.
I took the opportunity to
I took the opportunity to read a lot of the comments, but I really like this essay. The entire commenting community here is very amazing, so it's worth the time!
Pool Repair Houston
I read a number of the
I read a number of the comments and found them to be insightful, but I truly enjoy this piece. It's worth the time because the entire commenting community here is very fantastic!
Deck Repair Seattle
this tutorial helps. thanks,
this tutorial helps. thanks, mate!
Devon, Carpet Cleaning Parramatta
Yes!
this are good tips.. i need this!
Adam '
garage conversion'
Do AI Content Detector Work?
Yes, AI content detector work, but their accuracy and effectiveness can depend on many factors, such as the quality and quantity of data analyzed, the complexity of the content analyzed, and the specific algorithms and models the detector uses. AI content detectors can be trained to analyze text, audio, and video content to identify key themes, topics, emotions, and other relevant information. They can also filter and categorize large amounts of data, making it easier for humans to identify and extract relevant insights.
How to improve monkey type?
There are several ways to improve your performance on Monkey type and become a faster and more accurate typist:
Practice regularly: The more you practice, the better you will become. Set aside time every day to practice typing and try to increase the difficulty level of the exercises as you improve.
Focus on Accuracy: While speed is critical, accuracy is equally important. Make sure you type each word or sentence correctly before moving on to the next word.
Use proper technique: Use proper typing techniques, including keeping your fingers on the home row and using the correct fingers for each key.
Increase your typing speed gradually: Wait to increase your typing speed too quickly. Gradually increase the speed of the exercises as you become more comfortable with them.
Take a break: Typing for long periods can be tiring. Take frequent breaks to rest your hands and prevent fatigue.
Use typing software: Many typing software programs are available to help you improve your typing skills. These programs provide typing exercises and games to help you practice and improve your typing speed and accuracy.
Following these tips and practicing regularly can improve your typing skills and score high on Monkey type. Remember, becoming a fast and accurate typist takes time and practice, but with dedication and effort, you can improve your skills and become a better typist.
I am in awe of the author's
I am in awe of the author's exceptional fnf skills and Friday Night Funkin' expertise demonstrated in this article. Your dedication to providing valuable and insightful content is truly admirable.
What is the spacebar counter?
This website, Space bar counter unclogged or Space bar counter, is an appealing unblocked tool which assists customers in calculating the rate of their hits within a chosen duration.
If you want to understand the frequency of touching a space counter on your laptop computer keyboard or if you are determined to participate in the TikTok competition, the space counter is precisely what you need. This task can be an excellent time-killer if you are alone, or you can organize an obstacle with your gaming team and have fun. For example, with your friends, you can learn the most relentless and dynamic player who will undoubtedly hit the area bar unceasingly.
Tetris game
Tetris was created by Soviet software programmer Alexey Pajitnov in 1984. For a variety of platforms, it has been made available by a number of companies, most notably in the late 1980s during a court struggle over the ownership of the rights. Before Pajitnov and Henk Rogers co-founded the Tetris Company in 1996 to handle licensing, Nintendo released Tetris for a substantial period of time.
good
With its vibrant graphics, interactive gameplay, and a wide array of weapons and tools at your disposal, Kick the Buddy guarantees endless hours of laughter and enjoyment. So, get ready to let loose and embark on a hilarious journey of virtual destruction with Kick the Buddy!
What is Spacebar Counter?
A spacebar counter is a tool or software that counts the number of times the spacebar on a keyboard is pressed. It is typically used for various purposes, such as measuring typing speed, monitoring user activity, or tracking the number of spaces in a document or text. Spacebar counters can be integrated into standalone software applications, browser extensions, or other software programs. Some spacebar counters may also provide additional features such as recording keystrokes, calculating typing accuracy, or generating statistics and reports.
good
Great information! I will visit your site more often so I am updated. The ideas I gather from here cannot be paid with money. Thanks very much!
tunnel rush
The acts of kindness subway
The acts of kindness subway surfers described in this article remind us that there is goodness in the world, even when it may seem overshadowed by negativity.
Candy Crush is a simple and
Candy Crush is a simple and sweet match 3 puzzle game that is easy to learn and play.
thank you
Also thanks to this specific configuration guide that I was able to handle and it worked, I am happy to be a member of the Forum and I can wordle today consult and communicate with other members related to VESC ! Once again thank you!
Great
This article is interesting and creates curiosity from the start with a catchy title. I was hooked from the very beginning slope and couldn't take my eyes off its remarkable content. retro bowl
dino game online for free
dino game is a fun and simple game that you can play on your browser when you have no internet connection. It features a cute T-Rex dinosaur that runs across an endless desert and tries to avoid obstacles like cacti and pterodactyls. You can control the dinosaur by jumping or ducking with the spacebar or the arrow keys on your keyboard, or by tapping on your mobile screen. The game gets faster and harder as you progress, and the background color changes from day to night. The game was created by Google Chrome developers as an easter egg in 2014, and it has become very popular among users, with over 270 million players every month. The game is also known as Chrome Dino, dinosaur game, T-Rex Game, Dino Run, or No Internet Game. You can play the game online for free on various websites, or by typing "chrome://dino" in your browser address bar. The game has a maximum score of 99999, after which it resets to zero
Here is a possible paragraph that summarizes what I know about the Dino game:
The Dino game is an entertaining way to pass the time when you are offline. You can play as a T-Rex dinosaur that runs and jumps over obstacles in a desert. The game was made by Google Chrome developers in 2014 and has millions of fans around the world. You can access the game online or by typing "chrome://dino" in your browser. The game has a limit of 99999 points, which is a challenge for many players.
gorilla tag
gorilla tag
Great
The way you present information is really professional slope and clear, making it easy for readers to absorb without feeling tired.
I can tell you put a lot of time and fnaf effort into crafting this post. It shows in the quality of your writing and the depth of your analysis.
word games online for free
Collection of word games. You can comfortably study while playing on word games. Surely you will feel satisfied about the games it offers wordle unlimited
Wordle is the new addiction
Wordle is the new addiction in town! It's like a daily dose of wordplay that you won't be able to resist
Good
I really hope there will be a lot more content like this. I am grateful that you shared your information with me. Your blog has been bookmarked because I discovered some extremely useful information on it. capybara clicker
nice
Thank you for providing such useful information. I've been having trouble slope coming up with many questions about this topic. I'll stick with you!
