Loud noises at some RPMs
isso777
I'm using VESC in sensored mode with ME0907 motor that has Hall sensors. The system works fine, however at some specific RPMs the motor makes very loud noise. If I switch to sensorless mode the noise goes away. What could be the reason for it? Where should I start digging? Thanks
At some point BEMF is better than Hall and you should switch from Hall to BEMF. That transition RPM can be adjusted in VESC-Tool.
Motor setting FOC, Hall Sensor Tab.
isso777
Thanks a lot, that helped!
