Importance of the MK version and Determining the MK version of the VESC
10 posts / 0 new
alexantosh
Last seen: 4 years 1 week ago
Hello. I have a VESC6 based ESC. It is VESC tool compatible. I want to flash the VESC_servoout.bin firmware onto the ESC. Now I have the following two concerns stemming from the fact that its only till VESC tool 2.03 that the VESC_servoout.bin firmware is provided. I managed to find the repo that contains these firmware bin files  but there are different versions depending on the VESC's MK numbers (III, IV, V ...).
1. Is there a way that I can determine the MK number of the VESC that my ESC is using?
2. Is flashing the ESC with a different MK numbered VESC_servo_out.bin firmware from the one the VESC is actually using fatal to the VESC? or will it just not work? Depending on the risk. I will hope there is a way to determine the Mk number. If not then I will try them out one by one.
Thanks for your guidance.
Last seen: 3 months 5 hours ago
The manufacturer should be able to give you the Information. What FW does VESC-Tool suggest? That actually depends on what VESC-Tool finds on the device.
alexantosh
I have a FSESC6.6. The manufacturer is Flipsky. I contacted them and they said they don't have and don't know the MK version number. I installed the vesc-tool version 2.03 because it comes with the VESC_servoout.bin firmware which i need for my application. The tool says that there are updates for the firmware but he current one is 'mostly' compatible. Thats why i decided to first ask for guidance before proceeding. Should i install the latest VESC tool, look for its suggestion and then download a corresponding VESC_servoout.bin? Is this a safer approach?
Thank you a lot by the way.
alexantosh
Checking the FW, HW specs after installing the most recent vesc tool and connecting the FSESC, I can see that it has the following:
FW: 4.1, HW: 60
And the supported firmware loaded being: 4.1. Is it safe to assume that this falls under the MK IV category? Also, is it ok to upgrade the firmware because the VESC tool still issues the same warning. that:
"The connected VESC has old but mostly supported firmware ..."
IF it pops as HW60, then it is the old HW 60 design and not MK 3-5. MK3 had a different IMU, MK4 hibernation, MK5 has additional phase filtering.
alexantosh
ok, now am a bit confused. Indeed it does pop as HW 60. So whats the  compatible VESC_servoout.bin version to this hardware if it is not MKIII, MKIV or MKV?
Also as update, I upgraded the firmware the the default suggested firmware for now, just to make sure nothing is out of place. So as of now it is showing:
FW: 5.2, HW: 60.
What i need is the version of VESC_servoout.bin firmware that is compatible to this ESC. Thank you very very much frank.
You need to ask the manufacturer. They designed it. This is the repository for the standard FW supplied by Vedder: https://github.com/vedderb/vesc_tool/tree/master/res/firmwares
alexantosh
ok thanks frank.
alexantosh
Hello frank, according to the manufacturer, they used the 60 from the standard repository. Just 60. how do i go about compiling, if necessary, the VESC_servoout.bin for that FW? Image below shows it. So how do i go about obtaining or compiling the compatible VESC_servoout.bin for this?
alexantosh
which hardware/board choice was selected for the above firmware in the configuration file. Apparently I need to recompile it after choosing the right board. Is it the:
HW60_VEDDER_FIRST_PCB // Probably this choice?
Thanks alot.
