How does Current mode work
vescflyer
How does current mode work in an uphill slope?
Moving forward at a slow speed. Can I reduce throttle to a stand still?
Can I even reduce the throttle a little bit more to move slowly backwards?
Simply, in current mode, throttle sets %amperage of the motor, like %5 throttle=%5 amperage, %95 throttle=%95 amperage, when climbing an uphill , if the current is lower than required current for moving on, it can stand still, and lowering throttle could make it to move backwards.And, if required current is less than the motor current, motor reaches max. rpm.
vescflyer
Perfect.
Thank you
