The connected VESC has test firmware, and this is not a test build of VESC Tool. You should update the firmware urgently, as thi
Thomas W Donohue
I am very new to using vesc.
I have a Trampa 2wd spur gear with two VESC 6
I am trying to get the firmware updated but I get this message
The connected VESC has test firmware, and this is not a test build of VESC Tool. You should update the firmware urgently, as this is not a safe situation.
Any help would be appreciated
and thank you .
osaoroblig
I am also having this same issue. Whenever I try to update the firmware it never takes.
Osa Allakamenin
dinosaw
Also having same issue.
You need to upload the bootloader first. There is a bootloader tab in Vesc-tools firmware menu. After uploading the bootloader, you can then update the FW.
