Double the Input voltage, now more rpm at load
martin2day
i think i need some help with my VESC Setup in my powerboat.
I run an Catamaran with an Lehner 1940-6S with 1510 U/V on 4S... i run the wizzard and it run okay.
https://www.youtube.com/watch?v=WV6xdJive-E
The wizzard also setup the Current Limit to 61A.
This is a slow setup for this bowerboat and so i goes up to 8S.. i run the wizzard again, with some little change in the paramter.
The max Current is also setup by the wizzard to 61A.
https://youtu.be/zqT_lIhoSkc
But. The Powerboat speed is not double.. it is not very faster than with 4S.
At no load i run the motor with much more rpm.. up to 45000 erpm.
What can i do to get more RPM at load?
Have a nice day
Martin
RSR
Last seen: 2 days 28 min ago
If the 3-phase current is at your limit (61A) then you need a lighter/smaller propeller for 8S or you can increase the current limit.
martin2day
Hello
thank you for your help. I install a new (slower) Motor 1940/13 with 1206 U/V and change the motor current to 70A and the batterie current to 60A.
Now i get muc more rpm and the rc boat run great with my own VESC Controller
https://www.youtube.com/watch?v=TIyzAEVqaHo
Have a nice Day
Martin
