VESC 75/300 FW Mosfet Temperatures problems
tecnico.solarboat
I'm trying to flash a custom firmware on the VESC so that I can have custom CAN messages on the Bus, such as Fault codes.
I have 3 different VESC 75/300 versions. One that I know is a REV_3 and two more that I'm not sure which version they are. The PCB inside the VESC says V1.1 and VESC Tool says Fw: 5.2, HW: 75_300.
With the default FW I have all that MOSFET temperatures, MOS1, MOS2, MOS3 and TEMP_Filtered. But if I flash the VESC with the my custom FW configuring the conf_general.h file with the following settings, I  lose this temperatures and I only have access to the TEMP_Filtered.
I have tried to flash this VESC with the option for REV_2 and it works and shows all temperatures but I have not tried to spin motors.
Look at the bottom of the case, there is a laser edging. R3 has a R3 at the end of the B/N.
R2 has a working internal NRF and should state V1.12 at the end of the B/N
R1 has no built in NRF but a footprint for a NRF chip.
REV 3 has a switch circuitry,  REV 1 and 2 have a NRF port.
tecnico.solarboat
Thanks Frank for the information. So according to the photo bellow ours should be a REV2 even though it did came with the firmware for REV1 installed given that the VESC Tool identifies it as a 75_300 and not 75_300R2 right?
Yes, it probably had the wrong FW on. The FW changed because of the internal NRFmodel was changed and pinout was different. VESC-Tool identifies the unit according to the FW it finds.
Just flash R2 FW and you are good. Sorry for the confusion!
