fsesc 4.20 CAN bus not detecting
LeonD
problems;
1) vesc tool dus not recognize second (CAN) vesc
2) motors not starting equal.
3) not able to connect to second vesc
video about problem; https://youtu.be/0If_Vksw65c
i now that both te motors work correctly.
i am contacting the seller about it and flipsky but they do not respond very fast so i thought i would ask here.
( i don't now if it is a hardware problem or software so i pud it in the "vesc tool" forum)
thanks in advanced
spacewalker
what I think you not enable  CAN  on 2nd vesc, that is why  from main VESC  you can not see   2nd one
Martin
LeonD
thanks for the reply,
the problem is that i am not able to connect my "slave" vesc to my computer (the fsesc 4.20 is 1 unit). i get a warning; "invalid serial port:\\.\com6"
i do not get this warning on the master vesc.
MartyMcFlyFord
MartyMcFlyFord's picture
Ok so I had same issue, turn off esc, switched Filpsk mother board to singe motor connected backup up then re uploaded firmware and Bootloader waited then unplugged flicked switch on motherboard and now I can see both motors... Now onto why I cannot change the brakes on my puc (too sharp) :)
^^^me^^^
