Regenerate 30V to charge 40V battery
musinov
Last seen: 2 weeks 2 days ago
Hi guys.
Do you think if the 80100 KV220 (7kWt) generates 31v at 6000 RPM as alternator being directly connected to an ICE, a VESC is still capable of regenerating and charging a 10S (40V) LiPo battery?
In theory, I guess YES. What about practice?
Cheers, Andrew
musinov
up! still looking for reply
cheers
Yep, it should work. The controller will boost the voltage from the motor to the set battery voltage.
