How to set max input voltage to over 57 volts?
johnny5in5
My battery is 57.82V on a max charge. I've tried to edit the max voltage settings but it won't allow me to go over 57V. If it's physically impossible for a VESC to run on over 57V then I understand, but if not then I feel like users should be able to override this safety feature (maybe with a warning message).
Is there any way to circumvent this? Would I have to edit a new version of firmware myself or something?
Which VESC do you have?
If it's a version that's rated to 60V regardless of what you set you've got almost no headroom for voltage spikes and will likely kill the VESC extremely quickly.
FatsoBatso
FatsoBatso's picture
Last seen: 3 weeks 5 hours ago
I have a 100/250. so it should be good to 100V. I can run it happily on 14s but when I add another battery to 21s I get a red light and an over voltage error. Ive set the battery parameters in the Gereral - Voltage screen. Is there something else I should be doing?
FatsoBatso it's probably better to have made a new topic as you're not johnny5in5.
The stock firmware has an internal limit built in that you can't override, for a 100/250 it is 96.0V
https://github.com/vedderb/bldc/blob/3a071cee2f76db24308a9fb00b7d7482748...
So are you:
a) sure it's a 100/250
b) got the right firmware
c) a 23s battery rather than 21s?
And as above, if you go too close to the voltage limits then the voltage spikes that are a normal part of rapidly changing torques with BLDC motors will cause you to exceed the absolute max voltage and destroy components or the VESC.
