VESC Mini 4.20 boots up inconsistently, any suggestions
Djmrozinski
I have 2 Flipsky Mini 4.20 VESC connected to two 10" hub motors. I have been able to connect and set up OK. When they are powered up at least 50% of the time, one vesc doesn't start properly. When it responds to a setRPM command it rub slowly in the opposite direction and never responses to any rpm increase commands, but it does stop if I send a setRPM(0). The opposite vesc starts and run properly. The next startup it will run OK.
I am using two UART ports on a ESP32 to send the setRPM commands to each individual vesc.  Tried to reflash and setup again but that didn't seem to help.
Any suggestions?
could be tried with paired via CAN.
