VESC not connecting
jetomit
VESC not connecting
i have a problem with connecing the flipsky FSESC6.6 to the VESC tool. When I try connecting it, it just says: Invalid serial port: \ \ . \ COM5. Im new to this and would really appreciate it if somebody wold help me.
katevixen
Last seen: 6 years 1 week ago
did you figure this out? i have no clue what im doing learning as i go
Kent Tabor
A couple of things to try.  First make sure the drive is powered up with your battery.  The Flipsky brand drives I've used, won't connect if the unit isn't up to a high enough voltage. I have also found that if the serial port or other inputs are connected,  sometimes the USB port won't connect.
I
Kent
