Reprogram VESC for sensorless motor
Christopherinco...
Sensor wires ripped off one motor in an unfortunate accident. Wondering if I need to reprogram the vesc on my dual Flipski 4.2 or if I can just unplug the sensor leads on both sides of esc and ride on.
Christopherinco...
<p>Sensor lead was ripped off motor in an unfortunate accident. Do I need to reprogram vesc tool on my Flipski 4.2 dual esc? Or can I just unplug both leads and ride on...?</p>
It will run with sensors unplugged in sensorless mode. But I would still run the vesc tool and adjust openloop erpm, etc to make sure you get a smooth start in sensroless mode and disable the sensors in the FW anyway.
