Requesting fault codes over UART
spork
spork's picture
I'm currently using the UART continuously to show me my speed, battery remaining, amps drawn...  I do this via bluetooth and display it on an LCD display on my remote.  I also log the values that are returned from a COMM_GET_VALUES command.  My question is this... How can I capture fault codes?  I see there's an "mc_fault_code fault_code;" in the mc_values struct.  Does that mean it will return the most recent fault code?  What if there are multiple faults?  Do I have to clear a fault in order to see the next one in the list?
Thanks very much for any tips.
Pimousse
The fault included in the COMM_GET_VALUES is the current fault if one.
If no fault, it sends 0 (zero).
You have to play with COMM_TERMINAL_CMD and decode the output for retrieving past faults.
