Pole Pairs
donrecardo
Pole Pairs
Hi in the VESC tool for setting the max RPM it asks for the
number of pole pairs . In my motor there are 36  coils  and 30 magnets
so is it 18 pole pairs  (from the coils)
or is  it 15 pole pairs  (from the magnets ?)
Cheers
Don
rpucciano
Last seen: 1 month 1 day ago
Hi, for counting poles you have to, or either shortcircuit two of the three wires from the motor, and spin rotor un turn counting how many cogs you can feel, or apply 2 - 3 volts with some current (let´s say 3 amps) on 2 of the 3 power wires from the motor, and again spin rotor 1 turn, and count how many cogs per turn you can notice
rpucciano
motor poles usually are not the same as amount of magnets or coils, depending on motor config. of magnets and coil windings
hope this is useful
cheers
I was under the impression that it's half the number of magnets, because each magnet is either north or south, so you need a count of the north & south pairs.
As you've counted 30 magnets, that would be 15 pole pairs.
Bgbalz75
Hi, I have a 2023 Lifan E4 3000w scooter with a bosch hub motor how many poles does this motor have.
Does the number of poles incorrectly written to the vesc affect torque or just gives the wrong rpm. The controller is a flipsky 75 200 pro v2.
