Magnetic 3 phase linear motor with VESC
Mr.ironic
im on project which includes blcd linear motor. Can VESC drive with these kind of motors? These motor have encoder some models builtin.
s0313045
same... very curious.... what is the model and price of this linear motor?
Mr.ironic
This motor is 0905 model. these motors are not cheap. above 100USD mark. Some motors goes up to 1000 usd.
s0313045
Thank for the reply.... Considering the BLDC motor nature, I do believe VESC will work on these.
(I chose VESC to build most of the robots because it support DC,BLDC.... I can basically plug every mid-small scale motor I found in the lab and make it work)
However, during the calibration process of VESC on normal BLDC motor, the motor will rotate itself. So in your case, I think the linear motor will move left and right for a little bit.
That might be a problem...? (or maybe not)?  I am not quite sure
If you decided to go-on and test it, please let me know the result!!!!
