VESC Firmware (conf_general.h)
HopeAndWonder
Hey guys,
I am currently trying to build my own firmware on windows. My hardware design is based on HW 4.10, therefore I uncommented it in the conf_general.h. When building my code in Chibi Studio everything seems to work fine. In the build folder in my file directory a new .bin file is generated. However after flashing the file I cant get a USB connection in the VESC tool. Then i have to use my STLink  to unbrick my VESC. Therefore I select the vesc_default.bin file which is located in the build_all/410_o_411_o_412 folder. When flashing this file the VESC works fine again and a USB connection can be established. Obviously this file was generated by benjamin and does not contain any changes done to the firmware from my side. Any ideas what I am doing wrong?
Edit: This even happens when I just rebuild the code without doing any changes to it. Also inculded the first lines of the conf_general.h file
#ifndef CONF_GENERAL_H_
#define CONF_GENERAL_H_
// Firmware version
#define FW_VERSION_MAJOR			5
#define FW_VERSION_MINOR			01
// Set to 0 for building a release and iterate during beta test builds
#define FW_TEST_VERSION_NUMBER		0
#include "datatypes.h"
// Settings and parameters to override
//#define VIN_R1						33000.0
//#define VIN_R1						39200.0
//#define VIN_R2						2200.0
//#define CURRENT_AMP_GAIN			10.0
//#define CURRENT_SHUNT_RES			0.005
//#define WS2811_ENABLE				1
//#define WS2811_TEST					1
//#define CURR1_DOUBLE_SAMPLE			0
//#define CURR2_DOUBLE_SAMPLE			0
//#define AS5047_USE_HW_SPI_PINS		1
// Disable hardware limits on configuration parameters
//#define DISABLE_HW_LIMITS
 * Select only one hardware version, if it is not passed
 * as an argument.
#if !defined(HW_SOURCE) && !defined(HW_HEADER)
//#define HW_SOURCE "hw_40.c"
//#define HW_HEADER "hw_40.h"
//#define HW_SOURCE "hw_45.c"
//#define HW_HEADER "hw_45.h"
//#define HW_SOURCE "hw_46.c" // Also for 4.7
//#define HW_HEADER "hw_46.h" // Also for 4.7
//#define HW_SOURCE "hw_48.c"
//#define HW_HEADER "hw_48.h"
//#define HW_SOURCE "hw_49.c"
//#define HW_HEADER "hw_49.h"
#define HW_SOURCE "hw_410.c" // Also for 4.11 and 4.12
#define HW_HEADER "hw_410.h" // Also for 4.11 and 4.12
// Benjamins first HW60 PCB with PB5 and PB6 swapped
//#define HW60_VEDDER_FIRST_PCB
// Mark3 version of HW60 with power switch and separate NRF UART.
//#define HW60_IS_MK3
//#define HW_SOURCE "hw_r2.c"
//#define HW_HEADER "hw_r2.h"
//#define HW_SOURCE "hw_victor_r1a.c"
//#define HW_HEADER "hw_victor_r1a.h"
//#define HW_SOURCE "hw_das_rs.c"
//#define HW_HEADER "hw_das_rs.h"
//#define HW_SOURCE "hw_axiom.c"
//#define HW_HEADER "hw_axiom.h"
//#define HW_SOURCE "hw_luna_bbshd.c"
//#define HW_HEADER "hw_luna_bbshd.h"
//#define HW_SOURCE "hw_rh.c"
//#define HW_HEADER "hw_rh.h"
//#define HW_SOURCE "hw_tp.c"
//#define HW_HEADER "hw_tp.h"
// Benjamins first HW75_300 PCB with different LED pins and motor temp error
//#define HW75_300_VEDDER_FIRST_PCB
// Second revision with separate UART for NRF51
//#define HW75_300_REV_2
//#define HW_SOURCE "hw_75_300.c"
//#define HW_HEADER "hw_75_300.h"
//#define HW_SOURCE "hw_mini4.c"
//#define HW_HEADER "hw_mini4.h"
//#define HW_SOURCE "hw_das_mini.c"
//#define HW_HEADER "hw_das_mini.h"
//#define HW_SOURCE "hw_uavc_qcube.c"
//#define HW_HEADER "hw_uavc_qcube.h"
//#define HW_SOURCE "hw_uavc_omega.c"
//#define HW_HEADER "hw_uavc_omega.h"
//#define HW_SOURCE "hw_binar_v1.c"
//#define HW_HEADER "hw_binar_v1.h"
//#define HW_SOURCE "hw_hd.c"
//#define HW_HEADER "hw_hd.h"
//#define HW_SOURCE "hw_a200s_v2.c"
//#define HW_HEADER "hw_a200s_v2.h"
//#define HW_SOURCE "hw_rd2.c"
//#define HW_HEADER "hw_rd2.h"
//#define HW_SOURCE "hw_100_250.c"
//#define HW_HEADER "hw_100_250.h"
//#define HW_SOURCE "hw_unity.c"
//#define HW_HEADER "hw_unity.h"
//#define HW_DUAL_CONFIG_PARALLEL
//#define HW_SOURCE "hw_stormcore_100d.c"
//#define HW_HEADER "hw_stormcore_100d.h"
//#define HW_SOURCE "hw_stormcore_60d.c"
//#define HW_HEADER "hw_stormcore_60d.h"
//#define HW_SOURCE "hw_stormcore_100s.c"
//#define HW_HEADER "hw_stormcore_100s.h"
#endif
#ifndef HW_SOURCE
#error "No hardware source file set"
#endif
#ifndef HW_HEADER
#error "No hardware header file set"
#endif
#ifdef USER_MC_CONF
#include USER_MC_CONF
#endif
#ifdef USER_APP_CONF
#include USER_APP_CONF
#endif
UncleJoe
Last seen: 3 years 1 week ago
I was in the same situation, until I debugged with GDB. The 1st thing I did wrong was use GCC 9.2, which crashed in memset due to using unrecognized NEON instructions. After switching to GCC 8.3, it was getting further, but rebooting after a few seconds. Aha, must be the watchdog timer. I turned it off and finally can connect to VESC-tool. The settings can be changed and even real time data collection for the PPM app works, but nothing can turn the motor.
I'm using master, with last commit on 5/12/2020. Is that a stable branch?
judylee
I also have the same problem, hope to get help
resume examples
