RPM Limit not working
chinzw
Using BLDC Tool i could limit my board's rpm using the PPM limits. This options are gone and i've looked everywhere and just can't find a way to limit my boards speed anymore, hence making it unsafe/unusable.
Jobbel
You can just limit your ERPM at the Motor Settings > General > RPM Tab
This limits your speed/RPM even smoother than with the old Firmware
chinzw
Well, that doesn't work, at least not in FOC, that's why im posting here.
Last seen: 1 day 16 hours ago
It should work, but maybe not without load. Can you try setting a very low rpm limit and see if the motor has any torque above that rpm?
chinzw
Thanks Ben,
I'll give that a try when i get back home.
Yes, I confirm that thing, without load it may not work, because the current can be very low with some motors.
