The VESC software is free and open source, and can be found on github. This is the source code for the firmware that runs on the VESC hardware:
https://github.com/vedderb/bldc/
this is source code of VESC Tool, which is used to configure, control and monitor the VESC hardware from desktop and mobile platforms:
https://github.com/vedderb/vesc_tool
the VESC BMS firmware can be found here:
https://github.com/vedderb/vesc_bms_fw
The software is released under the GNU General Public License version 3.0. Instructions on how to set up an development environment and build the software can be found in the pages below this page.
Comments
vesc for mac?
Is there any chance to run vesc tool on Mac?
Mac version 1.08 (Works perfectly)
https://github.com/rpasichnyk/vesc_tool/releases/tag/v1.08
vesc not connecting
hello, I have read all that I can on connecting my flipsky dual vesc6.6 to the macbook tool but it still doesnt connect/recognize its plugged in. What am I missing? What else do I need to do to get it to conenect? Any help on this would be great as its been a grusem time trying to troubleshoot this. No where can I find any good help as to what I need to do...
Mac version of vesc_tool works just fine.
I've been using vesc_tool on Mac without issue. Just install the full Qt5 library, git clone https://github.com/vedderb/vesc_tool and compile it.
Also, on Ubuntu you need the full Qt5 installation, not the default stripped down one.
Hello, I am trying to get
Hello, I am trying to get this tool to work on my mac and im not sure what your talking about for compiling. How do I do that?
Firmware changelog?
Hi.
Where can I view a changelog for the firmware and also is there a way of knowing when firmware has been updated so I know when to flash my vesc?
Cheers
Steve
firmware
What is the latest firmware ??? and where can i get it ???
Scott
Precompiled for Windows
It looks like people have precompiled VESC Tool for windows, but I'm not able to find it? Any hint?
Is it possible to run it on Windows, or do I need to compile for it?
Did you manage to build it on
Did you manage to build it on windows?
Chibios is the answer: http:/
Chibios is the answer: http://vedder.se/forums/viewtopic.php?t=165&start=20
If you have java JRE problems: https://wiki.ugfx.io/index.php/Using_ChibiStudio
Mac version of Vesc Tool
I was very happy with the old version of the BLDC tool. I can't manage to run the new vesc tool on mac.
I would really be happy to have some help.
I read erwincoumans message but I don't understand what compile means, I am not a programmer.
I also downloaded a Ubuntu version of the Bldc tool but it doesn't seem to run on the demo dvd.
Thanks for the answers.
Already exists
prova vesc
provare vesc
Download software VESC Tool for Windows
Hi, I bought a VESC on Amazon (FSESC 4.12) and I would like to download the VESC Tool for Windows software.
After placing it in the cart, when I click buy (also the Platinum version) the cart is emptied and I do not get anything else.
I would like clarification for the download.
Thank you for your quick answer.
Luca Torani
Problemas na aquisição do software
Olá Lucas, estou com o mesmo problema que vc, após adicionar o programa, quando vou finalizar aparece a informação que o programa foi retirado do carrinho.... Vc consegue resolver o problema???
To establish Bluetooth communication with self made android app
How's the data transmitted from mobile to Bluetooth module when we try to communicate with the board? Say user wants to move forward, does the provided android application in the website transmit data as "forward" in the form of strings to the Bluetooth module?
of course not! lol!
of course not! lol!
You would need to understand A LOT of the code than Benjamin made and based on your question you clearly don't. Download the source code for the vesc tool and try to understand how it uses the keyboard as input.
Computer doesn't recognize Esc
For some reason my computer doesn't recognize my Flipsky FSESC 4.20. evrything is plugged in and powered, ive tried 4 different usb cables, different ports, and also different computer. I feel like im missing a driver or something for it to recognize it? any help is much appreciated!
weeeeeee
Flipskys are not built on high end components like a genuine VESC. I have scrapped 2 of 2 flipsky, 3 of 3 VESC are still pushing. I suggest for safety reasons to save flipsky for remote rc vehicles.
As far as plugging into them, for the short time they worked, windows update was able to locate all needed drivers to work with VESC tool.
is there docs for a windows build environment for vesc firmware
I want to add pedelec function to the firmware if its already don by someone?
else i need a guide to set up build environment to get "make upload" running
Here I found a tip
https://vesc-project.com/node/748
Releases of firmware on github
Where can I find specific source code releases of different versions of the firmware? Many VESCs in the past use firmware version 2.18. Where is the source for that version located?
Thanks.
I NEED vesc tool 1.02 for
I NEED vesc tool 1.02 for windows.Can you help me please ?
For 3 months now I’ve been trying to compile the sources
For 3 months now I’ve been trying to compile the sources on both Windows and Ubuntu. All time, some kind of mistakes, something lacking. It is unbearable. Can someone make a project that compiles without without a "shamanic tambourine"?
Hooray, I finally compiled
Hooray, I finally compiled the source. I had to install Ubuntu 16.04 on Hyper-V (Windows10). The first time the commands were not executed. Complained about security problems (something like that). But at one point, after rebooting the OS, I put together the same commands from the instructions. And lo and behold, it has gathered. I am happy.
The source for installing the bar from here. https://cloud-images.ubuntu.com/releases/xenial/release/ubuntu-16.04-ser...
First I set it to 19.04 by default (so Windows makes a normal virtual machine with a network, etc.), and then installed this image with disk formatting (virtual) on this virtual machine
Linux precompile file
Can someone explain how to install the linux precompile file?
Thank you
engineer
is the The free and open source VESC software can run on the vesc 6 plus?
Compiling VESC firmware on Windows
Has anyone tried to use the latest Chibi Studio for Windows to compile this firmware : ChibiStudio_Windows_2020-04
Thank You
hello, I have successfully
hello, I have successfully used ChibiStudio_Windows_2020-04. the way is to extract the file, don't use WinRAR, but use 7zip.
now I'm trying to find out how to download VESC hardware via ChibiOS with Windows 10 OS. Does anyone here have a video tutorial?
Asking for Paltatech Hardware and Firmware
Hi all, now I am working on a VESC project which is the hardware is based on paltatech. Now I'm confused because the source codes for the firmware that supports Paltatech hardware on github are incomplete (there are some missing libraries).
I have also purchased a platinum VESC tool, I think I can download the latest firmware with the hardware version of Paltatech. but i see nothing.
do you have a solution or do you have a complete source code file with hw version paltatech?
thank you
WHEN I AM BUILDING THE VESC
WHEN I AM BUILDING THE VESC CODE ,
ITS SHOWING QMainWindow: No such file or directory
HOW TO RESOLVE IT
My God, this site has been
My God, this site has been taken over by troll bots.
