Current KP(Current controller proportional gain)
Geir Henriksen
607/5000
I have a problem that the motor stops at abrupt start-up and when the wheel is released during acceleration on loose ground / dirt road. When I use Setup Motors FOC with VESC Tool I get Current KP (Current controller proportional gain) = 0.0097. I have gradually increased this value, and at KP = 0.07 the problem is solved. Do I risk anything by increasing KP to 0.07? The engine runs fine and I notice no negative symptoms. I use this engine from Scorpion; https://www.scorpionsystem.com/catalog/aeroplane/motors_1/sii-55/S-5535-... and VESC 6 with AS5047 Encoder on a GoPed scooter.
Best regards
Geir
Ricardo Bosqui
Hello my friend
I had the same issue, just multiple per 10 the value and my worked really fine!
Ricardo Bosqui
