What's general algorithm of firmware?
Furkan Kaşku
I  look at firmware files but I couldn't figure out the main algorithm for motor control.
Is there a schematic diagram of code?
That makes more understandable for me.
The code is well organized. That should be sufficiently enough to figure out things but if you can't, it's not a code problem.
