VESC 6 CAN Command and Telemetry Formats
TerraHawk
I have looked all over and failed to find command and telemetry information in a convenient package. I dug through the VESC 6 firmware and extracted what I believe are the correct formats.
I am looking for somebody to glance over my PDF and see if the formats look roughly correct. I will get to test  it next week to verify but if I have made an obvious error, it would be good to learn it now.
Thank you.
VESC6_CAN_CommandsTelemetry.pdf
ProtonZ
Last seen: 5 years 4 weeks ago
I am looking for the way to control VESC via CAN too. And I really want to know if your format documentation is correct if you have tested it. Thanks for giving me an example.
Pimousse
I'm maybe late, but anyway.
Here you may find a document I wrote up regarding VESC Communication : https://drive.google.com/open?id=1j8Lni4cAb5P5hYK-VS-Ex2eKzMCK7ZKI
Check the COMM CAN tab (UART communication is maybe outdated).
Tinkerer
Edit: Deleted my comment as I realised I've been approaching it wrong.
Configuring the VESC hardware I have to transmit status messages over CAN is done directly in the VESC tool. I'm able to read all packets being sent using my Arduino with a CAN shield now. Thanks for the documentation here - helped big time!
flatspot
Last seen: 4 years 2 days ago
Hi TerraHawk, Pimousse,
The information provided seems correct.
The DBC i made from it seems functional so far.
https://vesc-project.com/node/2678
This Thread made it so much easier to build the DBC, so massive thank you for doing the Overview.
Best Regards
