FAILED DETCTION. REASON:-11,and FAULT_CODE_DRV
marco esteban l...
hello, I  have a  problem, I  bought two  new vesc with firmware 3.38. when I connected to my pc in BLDC tool, it showed a message saying that the firmware was too old. so I began to use VESC tool, I updated the firmware  to 3.62 and I was trying to connect the motors clicking in wizard >setup motors FOC, but when I clicked on run detection the light red in the vesc blinked 3 times and  appeared a window saying detection failed reason:-11 , so I went to the terminal and there appeared " fault: fault_code_drv", I tried this with and without the receiver conected to the vesc and it gives the same message, I don't know if this information is matter but I clarify that  when  I conect the receiver with my vesc it always remains blinking , I tried to push "bind" in the transmitter and turn on it and a red light  remained in the receiver and a green blinking light appeared in the transmitter however I tried again the whole process and it didn't work. so  I have not been able to use the motors, I am not a professional, this is the first time  I build a skate , I hope you can help me, thank you
I use two lipo bateries of 8Ah and 22.2 v, conected in serie
and two motors sk3  6374 of 149 kv
and one transmitter GT2B
First of all, you can detach the receiver and run the motor Wizard. Single ESC, battery, motor is the best way to check things.
Your ESC is not a original VESC it is third party, so its hard to tell...
If the Wizard does not work, your device is probably faulty out of the box.
marco esteban l...
yees , it works, with single battery, esc, and motor.
thank you friend for the recommendation, I am very greatful, but do you know why it doesn't work with the two  batteries connected in serie , and the two esc connected by can -bus?
and I am confused the seller post in ebay that its original, how can I identify an original vesc?
