builtin ble on vesc 75_300
alexefoil
Hi , is it possible to switch off the builtin BLE in the 75-300 ?
i would like to use another BLE module for my iphone and the intern one may bug the other ...
thank you
Last seen: 2 weeks 5 hours ago
If you have the R2 hardware you can switch it off by setting Enable Permanent UART to false in App Settings > General. I don't think they will interfere with each other though.
alexefoil
Thank you, just tried that, it doesn’t turn it off ... i got it on the first batch so it is R1 ?
Xmatic app works with built in ble
metr at doesn’ t (all the Time) with their module ( i would prefer use their data log for my efoil...)
i wanted to make sure by turn off other Bluetooth signal
vesc not tested on water yet but thank you for created it
my setup
efoil rider
Another option that is possible with the VESC Tool version I uploaded yesterday is to erase the firmware on the NRF. Connect cables from IO and CLK on the SWD connector to the same lines on the NRF SWD connector and use the SWD Prog page in vesc tool to erase the NRF firmware. It is possible to write it back using the same method later too. Make sure to not short anything with loose wires when plugging them in.
overdrive
Hi how can i find out the HW Version of the Vesc 300?
Backside of the housing. V1.12 is R2
Glennisoty
Builtin be on vesc, Complete switching, and possible way to share essay help and to rely on it all is defined perfectly. I don't know what you think about how and why we are going to take those processes which shows me the importance which we start to see here.
