8. Updating VESC WAND remote controller
Submitted by frank on Mon, 2019-09-02 11:54
Update of your VESC WAND remote controller
In this tutorial we will update the firmware on a genuine VESC® WAND remote controller
VESC-Tool Firmware update_tutorial
Remove SWD Cable and close housing.
!!Remove batteries and then reinsert batteries!!
This procedure is important to take the Wand out of debug mode which constantly consumes power!
Your WAND remote is now updated and ready to use.
Comments
Is it possible to update the wand with the flipsky 6.6 plus dual as the swd plug is absent from the board
Lradcliffe
In that case you need to solder cables to the PCB. The SWD Port is part of the specifications that are available online. Third party equipment does not necessarily follow the VESC specifications even if it claims to do so. Version numbers are also no indicator you get a certain HW-Model/Revision with certain features.  Anyone can simply copy a revision number and naming, so that customers think its the same beast with the same features!
We design the VESC-Products to be compatible with the original HW output. Third party equipment does not necessarily need to be fully compatible.
I also have the flipsky vesc with the VESC Wand ... i can't see anywhere on the board where I would be able to find those connectors.
Is it possible to update the remote without using the vesc?
Hi I don't own a Linux or Windows PC.
Is there a way to update the WAND and the BT Dongle with my Android mobile?
I have 100% original VESC Hardware, bought at Trampa.
From when is it possible to connect the remote directly via the micro usb connection for updates? (the focbox has no SWD port)
