Flipsky VESC-clone firmware udapte problems
gui-rider
Hey,
I have a problem with my Flipsky Dual FSESC4.20 100A VESC, when I open vesc tool 1.09 and connect my VESC, it says that my vesc firmware is too old and that I need to udapte it, vesc tool 1.09 only support 3.55 firmwares, my vesc is 3.4, so I udapte the firmware in the software, everything seems to work, but after I reboot the VESC it still says 4.3 version and please udapte the firmware, over and over again.
Also I tried to udapte the bootloader, it doesn't fix my problem.
Does anyone now what the problem is ? If you don't, can someone at least send me the older (but "latest") version of the vesc tool firmware that supports 3.4 VESC ? that would be awesome.
Note that I tried to go through the motor configuration process but when It tries to identify/spin the motor, it reminds me that the version is too old.
subarucasey
Happens for me too. Using dual flipsky plus 4.20. But I notice if I keep trying to connect, after a few attempts it connects fine. Is it possible it just takes a bit to recognize the firmware version and clicking connect before that process completes, causes the error ? To be clear, I updated firmware only once. But upon subsequent boots of vesc tool, I click connect and see error saying I need to update. I don't actually need to update, and I can keep trying to connect and it works eventually.
bikekrazy
Hi, I was setting up the flipsky dual plus 4.20 and no matter what I do it won't recognize the hall sensors on my torqueboards direct drive motor kit. It always goes into senseless mode and it's a very rough  start on both motors. Btw I'm using flipsky vx2 remote.
arielle
Last seen: 7 years 3 weeks ago
The same error also happens for me.
avsha
Last seen: 6 years 12 months ago
does anyone have the 1.19 version? my fw is 3.61 and the latest tool supports 3.62 only. cant upgrade so i cant handle my controller.
